don't forget the foredeck
Posted by Howard on Feb 5, 2005
you may be able to do the hull...but i bet the foredeck is going to be a heck of a challenge if not impossible with 6mm. i do not think you will be able to bend it to the appropriate curve.
when you do a 4mm deck, it is already a lot of work to bend it. i cannot imagine being successful with 6mm.
i would do the boat with the 4mm. i think it will be too heavy and clunky to be done with any satisfaction with 6mm.
In Response to: CH16 hull thickness by Stephan Bradley on Feb 5, 2005
- Re: don't forget the fore by CLC on Feb 5, 2005
Re: don't forget the fore by allanreade@paradise .net. on Feb 5, 2005
- Re: don't forget the fore by Vic F on Feb 10, 2005
Re: don't forget the fore by Stephan Bradley on Feb 5, 2005
- try the skiff by Howard on Feb 5, 2005
- Re: try the skiff by Stephan Bradley on Feb 5, 2005
