Re: Joe Greenley Lashing
Posted by Dave Houser on Dec 29, 2004
I used a router with an 1/8" bit and a quickly made jig to make the slots. Quick accuate and easy once the jig was made.
You must seal all exposed wood on a kayak with epoxy or it will stain and/or rot.
Using Joe's method of melting the wedding together to weld them into a loop, creates a full flange at the base of the loop. Joe's says he just silicones them in place and that is what I did. They do not leak.
Joe Greenley's Soft Padeyes
In Response to: Joe Greenley Lashing Tabs by Greg G. on Dec 23, 2004
- Re: Joe Greenley Lashing by LeeG on Dec 29, 2004
