Re: dust extraction
Posted by Steve Miller on Dec 23, 2004
I use the same setup. Shop vac with good bag liner hooked to a Porter Cable ROS. I used to use the gortex filter but it clogged so fast I switched back to bags. I have built several boats bigger than kayaks using this system. Never thought to put the sander outside. The vac is quieter than the sander so I guess it never occured to me to do it for dust control. I do use a set of ear protectors for long sanding sessions. Full over the ear shooting style gear. My ears ring otherwise.
In Response to: Re: dust extraction by LeeG on Dec 23, 2004
