Re: panels cut - is it re
Posted by Chris on Dec 6, 2004
Have you tried laying out a baseline on your work table, and remeasuring your set backs, just to make sure you cut things right?
I think it is much more important that the left side & hull panels match perfectly to the right side/hull panels versus being bang on to the measurements provided in the plan. If the boat is 1/8" shorter or shallower or wider than the plans, but symetrically so, You won't notice, However, If the right side of the boat doesn't match the left side, you'll paddle in circles.
good luck,
cj
In Response to: panels cut - is it ready by ray on Dec 6, 2004
