Re: Shop tip: micro-ballo
Posted by Josh Ratty on Dec 2, 2004
Another trick i've used for pinholes is to use a very runny mixture of micro balloons and trowel it on with a good metal trowel. Put it on very thin, almost scraping it on, so that you are only filling the holes and not adding alot of sanding. Be sure to trowel in four directions over the surface to make sure the holes are completely filled. Good luck.
In Response to: Re: Shop tip: micro-ballo by Lance Alldrin on Dec 2, 2004
