strange that folks have
Posted by Charlie Jones on Nov 22, 2004
so much difficulty with the pumps. I've used nothing else (both MAS and WEST) for many years with no problems. Perhaps it's because I use them very very frequently?
For very small quantities I do meaasure- using a marked stick. I mark off 5/16 then another mark at 6 /16, put resin in to the first mark, then hardener to the second, mix and go. Never a problem. I use the inner section of spray can tops for very small amounts, measuring like that. The 2 -1 ratios are even simpler.
As I said, I really don't understand the problems.
In Response to: Re: Epoxy hardener pump by Terry Mcadams on Nov 22, 2004
- Ditto by Laszlo on Nov 22, 2004
- Re: strange that folks ha by Mark Camp on Nov 22, 2004
- Re: strange that folks ha by RogerJ on Nov 24, 2004
