Re: Leaking hatch seals
Posted by Gary Turner on Nov 13, 2004
I'd be very surprised if O-ring rubber works. It is WAY stiffer than foam rubber, so won't give as much, and therefore won't seal. You need the give in the foam to even out the differences between the deck and hatch curvatures - unless you are lucky enough to have a perfect match!
In Response to: Re: Leaking hatch seals by Gavin H on Nov 7, 2004
