Re: Leaking hatch seals
Posted by Gavin H on Nov 7, 2004
I've been experimenting with o-ring rubber to help seal my deck hatches.
Here in Australia, o-ring rubber can be purchased by the metre(yard), and I glued it to the hatch rim using super-glue (cyanoacrylate based glue). When I tried to remove the o-ring, bond was that strong that the rubber tore away from itself, leaving me with quite a job to remove the remaining rubber.
However, I don't beleive the super glue will stand up to a lot of water. My plans are to use epoxy to provide the long term adhesive solution, once I am happy with it.
My o-ring was about 1/4" diameter, but on one hatch this didn't seal well, so I am replacing it with some 1/8", hoping it will require less pressure to seal against the foam.
This is still very much a idea in progress
In Response to: Leaking hatch seals by Homer on Nov 6, 2004
- Re: Leaking hatch seals by Jay E. Morris on Nov 7, 2004
- Re: where in Aus, Gavin by Craig R on Nov 7, 2004
Re: where in Aus, Gavin by Gavin H on Nov 8, 2004
- Re: where in Aus, Gavin by David on Nov 9, 2004
- Re: Leaking hatch seals by Gary Turner on Nov 13, 2004
