Re: Leaking hatch seals
Posted by Craig Robinson on Nov 7, 2004
How much give do you have in you front hatch? If it is as stiff as it should using the prescribed construction method, then I don think the dowel will help. I wasn't happy with mine so I built another one with a tighter radius so that it conforms to the deck radius better. That and 1" x 3/8 foam. Cheers
In Response to: Re: Leaking hatch seals by Ron Miller on Nov 7, 2004
- Re: tighter radius by LeeG on Nov 7, 2004
Re: tighter radius by Terry Mcadams on Nov 8, 2004
- Re: tighter radius by LeeG on Nov 8, 2004
