Re: Hip foam + back band?
Posted by LeeG on Nov 1, 2004
One thing to consider is that the foam brace on the right drawing that isn't connected to the underside of the deck will tear out once a person settles into the kayak so a notch should be made for the sheer clamp and glued to the underside of the deck or velcro on top and sides. You don't need to notch out a slot for the back band as it will simply compress into the foam.
In Response to: Re: Hip foam + back band? by Tim M on Nov 1, 2004
- Re: Hip foam + back band? by Homer on Nov 1, 2004
Re: Hip foam + back band? by LeeG on Nov 1, 2004
- Re: Hip foam + back band? by LeeL on Nov 1, 2004
