Not Acetone
Posted by Ed on Oct 11, 2004
Aaron,
You need to scrape the sticky stuff off the boat. Then wipe the boat down with denatured alcohol or vinegar. Do NOT use acetone. Acetone is good for cleaning your tools, but could leave a residue on the hull causing epoxy adhesion problems later.
Remember, NEVER use a solvent to clean epoxy off your skin. I will thin the epoxy so much that it will be absorbed in your body. Use soap and water.
Ed @ CLC
In Response to: Scrape it off by Robert N Pruden on Oct 10, 2004
- Re: Not Acetone by Robert N Pruden on Oct 13, 2004
- Re: Yes Acetone by Jon T on Oct 13, 2004
