Re: double with sail rig
Posted by Terry Mcadams on Sep 10, 2004
Ditto to what Lee said on the rudder. Same goes for the leeboard. You'll probably need a larger sail, possibly a stronger mast tube and maybe even larger amas.
That puppy may be be a bear to tack, though experimenting carefully with boat trim and leeboard may help in this regard. Changing the crew may require a lot of retuning.
Still, it could be one fast boat in the right conditions.
terry
In Response to: double with sail rig by aaron on Sep 10, 2004
- Re: double with sail rig by Petewp on Sep 11, 2004
