Re: Bulkheads on angle?
Posted by Mark Camp on Aug 26, 2004
If there are
-no dimensions on the drawing to tell you the angle
-no dimensions telling where to locate the top and bottom of the bulkhead (effectively giving the angle), and
-no note on the drawing or instuctions telling you qualitatively how to angle it
then you have found an error in the plans and instructions, and according to CLC's recent post, they will gladly give you the missing dimensions or instructions, and will also correct the error so that builders who order the product in the future don't have the same question.
It is great to see these problems getting cleaned up, and CLC taking such a positive attitude about it, as I experienced multiple instances of this identical type of error when I was at that stage of the build, and these errors were a huge pain in the neck.
In Response to: Bulkheads on angle? by Michelle Moran on Aug 26, 2004
