Re: Deck Nails Too High
Posted by Doug Judd on Aug 22, 2004
Ray, how many coats of epoxy have you applied to the deck? If you are going to add more, I would drive the heads flush using a flat punch (the head of a bolt works). Then go ahead with your final epoxy coats and sand everything smooth.
In Response to: Deck Nails Too High by RayA on Aug 22, 2004
- Re: Deck Nails Too High by RayA on Aug 22, 2004
Re: Deck Nails Too High by Kurt Maurer on Aug 22, 2004
