Re: I need a little help.
Posted by Howard on Aug 4, 2004
keep using the template to check for proper curvature every 6 inches. it will look like it is flattening out as the boat thins up to the bow...the curvature is quite hard to eyeball...but the template will tell you if you have it.
Sight down the bow from astern the boat (both sides) and ensure that you have no bubbles or waves....it should be a smooth, fair line along where you have the nails and all areas in between.
In Response to: Re: I need a little help. by Cain on Aug 4, 2004
