Re: Panels not ending eve
Posted by LeeG on Jul 19, 2004
the panels should be even left panel to right panel starting at the beginning and ending,,it's immaterial whether the side panels are even to the bottom panel, top to bottom. You can have some twist even if the mirrored panels meet up perfectly but you're guranteed to have gross twist if one side (left/right) is flopped over the other at the beginning or end. All this assumes that the two side panels are the same length and the two bottom panels are the same length. There's no reason to have knife sharp edges where the side panels meet at the ends so you'll be rounding over the overhanging panels anyway.
In Response to: Panels not ending even by Jay E. Morris on Jul 18, 2004
- Re: Panels not ending eve by Jay E. Morris on Jul 19, 2004
- wow.. by LeeG on Jul 19, 2004
Re: Panels not ending eve by Wade Bick on Jul 19, 2004
- Re: Panels not ending eve by Jay E. Morris on Jul 20, 2004
Re: Panels not ending eve by Chris Taylor on Jul 20, 2004
