Re: MC 16.5: Begin stitch
Posted by Steve Miller on Jul 15, 2004
Mill Creeks stitch right side up. The bow to bottom panel intersection (stitch starting point) has been the subject of many posts. Best bet seems to be to stitch both ends together then work the assembly back and forth until its centered on the bottom. Then note where the bottom meets the bow and stern. Look balanced and even at both ends? Each end is shape differently so check each end by pulling it all together.
Yes, as mentioned work 3 or 4 per side, alternating sides as you move back down the boat. Should line up fine.
In Response to: Re: MC 16.5: Begin stitch by Doug Judd on Jul 15, 2004
- Re: MC 16.5: Begin stitch by Peter Lyons on Jul 15, 2004
