Re: Similar Question
Posted by Myron on Jul 7, 2004
Open the joint as much as possible either by bending it back "carefully" and or putting something like a putty knife in the joint. Work as much epoxy in as possible. I usually use a toothpick. Then close it up, reclamp "gently" and let harden. A little void in there is not a large problem as both sides will be well coated and sealed with epoxy in later steps.
In Response to: Re: Similar Question by Mark Camp on Jul 7, 2004
- Re: Similar Question by Jay E. Morris on Jul 7, 2004
