Re: Bulkhead Question
Posted by Howard on Jul 7, 2004
if the gap is small between the top of the bulkhead and the deck....you can simply fill it with a fillet of thickened (peanut butter consistency) wood flour.
this is fairly routine to do this...no wood needed in my opinion unless the gap is more than a 1/4 inch ...once you do the fillet from one side...when you open up the hatch...repeat the fillet operation from the other side.
hs
In Response to: Re: Bulkhead Question by Irv Kooris on Jul 6, 2004
