Uh Oh...
Posted by Kurt Maurer on Jul 1, 2004
You didn't glue the sheer clamps to the wrong edges of the panels, did you?
The spreader stick goes in the *top* part of the hull, and the lower edges of the side panels slant in towards the bottom panel edges. This gives your hull sides a little "flare". Just know that the hull sides are NOT intended to be vertical; they should "tilt" inwards at the lower edges to catch the bottom at the chines. All this is reversed on an upside-down hull, of course...
Cheers, Kurt
In Response to: Re: Hull Stitching on Che by mike noeske on Jul 1, 2004
- Re: Uh Oh... by Gary Turner on Jul 3, 2004
