Re: SWAG
Posted by BobE on Jul 1, 2004
The enter key has a mind of its own.
You mentioned: �So my conclusion is that my epoxy is contaminated. I recently recharged the original batch with the same brand same slow hardener�
Did you happen to attempt to clean the pumps as well with some solvent? What happens if you mix a batch by pouring into measured cups instead of using the pumps?
As LeeG noted, compressed air can contain atomized compressor oil or moister unless well filtered. Hope you figure it out soon!
In Response to: Re: SWAG by BobE on Jul 1, 2004
- Re: SWAG by Charlie Tuna on Jul 1, 2004
