Re: The Saga Continues
Posted by Dennis Rioux on Jul 1, 2004
The orange chunk seems quite similar to what I experienced (see "one more maybe"). It might be that tiny coagulated bits of hardener are floating around in your mix and do not get dissolved properly in the resin. I am relatively certain this is where I ran into my problem with fisheyes -- each of them had a little particle in the middle that I attributed to my hardener burp. I wonder if you could strain some hardener through cheesecloth or something and try a small test batch on yet another board. But if you cannot see little bits maybe this is not the problem. Of course, your solution to get brand new materials may be the easiest of all. Good luck.
Dennis
In Response to: The Saga Continues by Charlie Tuna on Jul 1, 2004
