2 suggestions
Posted by Myron on Jul 1, 2004
Pieter,
I just finished my own custom design which has an extended cockpit opening and is much easier to use than the standard Ches. If you want instructions, ask.
LeeG, who posts here regularly, has talked about taking the deck beam(s) out of a kayak after construction. I'm not sure I would take the back one out as I sit on that area getting in and out, but the front one could be taken out or moved forward allowing for a larger cockpit opening or just not be in the way of your knees.
Good luck!
In Response to: tight fit by Pieter Braam on Jun 30, 2004
