Re: The Home Stretch
Posted by Steve Miller on Jun 28, 2004
No solvent on the new paint! After wet sanding just wash with plain water. No soap needed. Wipe dry with clean rags. Should be ready to go.
I find that any little paint or varnish creep can usually be removed at the tape line with a dental pick and a gentle touch. Thinner causes other problems. Do your picking as soon as you can.
In Response to: The Home Stretch by Brad Wells on Jun 28, 2004
- Re: The Home Stretch by Brad Wells on Jun 28, 2004
