Re: Exterior gap filling?
Posted by Dave Houser on Jun 24, 2004
If you round over (sand) the chines and shears, it really doesn't matter if the epoxy is darker because four of the plywood plys will show anyway. I have found that epoxy mostly thickened with fumed silica and colored with just a little cedar wood flour will match the Okoume plywood. Beware cured epoxy thickened with Cabosil (fumed silica) is very hard to sand. If you use it be sure to get the surface smooth at application and scrape the next day. After a hard cure the stuff is bulletproof.
In Response to: Exterior gap filling? by Archie M. Sullivan on Jun 24, 2004
