Re: Removing Water Stains
Posted by Niels G. Mortensen on Jun 22, 2004
Bo - you can use oxalic acid for this. Quite efficient, but it has to be washed out of the wood thoroughly in order not to create problems with the varnish/paint that follows.
So, a better way - that I have tried recently with some success on mahogany - may be a solution of 10% hydrogen peroxide and 2-3% household ammonia. Use repeatedly on the black spots until they are gone. Wash with clean water, let dry thoroughly, and you're ready to varnish. Wet the wood before any treatment (one or the other). -- Niels
PS. The original advice in Swedish is: "Stryk p� en l�sning av 10%-ig v�tesuperoxidl�sning med en tillsats av 2-3% ammoniak �ver fl�ckarna. Upprepa tills de inte l�ngre bleks. Tv�tta bort l�sningen och l�t ytan torka ordentligt. Sedan kan du lacka p� samma s�tt som tidigare." If you know Swedish (!?), follow the link below.
Tr�b�tsakuten
In Response to: Removing Water Stains by Bo Williams on Jun 22, 2004
- Removing Water Stains by Troy on Jul 28, 2006
