Re: drills and paints
Posted by Doug Judd on Jun 7, 2004
I looked at the Fuller set and said, "No way!" I simply drilled a pilot hole, used a larger bit to accomodate the screw head diameter. (Sorry, can't recall the size.) I drove the screws in to just below flush with the hull panels and used thickened epoxy to cover them. When the epoxy is cured, scrape the excess flush and VOILA!!
In Response to: drills and paints by Chris F on Jun 7, 2004
- Re: drills and paints by Bill Cooke on Jun 7, 2004
