Rule of Thumb?
Posted by Mac on Jun 2, 2004
OK, I know before I ask that I'm dreaming if I think there is a simple answer to this - but I'm a newbie kayaker and hope springs eternal.
I have a 19' kayak that has an Artic Hawk type prow (ie: very sharp) with a Pax type stern. It is hard chined with a LT profile (ie: very low)). Bow and stern are very low volume - read knife edged. Beam at cockpit shear is 24 1/2". From what I can - see very little rocker. I was pathalogical about checking for twist.
I'm 6', 240lbs and stiff, my seatback is max rearward so I can (just) get in and out. From the photos I've seen, the yak still looks a teeny bit front heavy.
Paddling into the wind and chop is fantastic, as the weathercocking and flow keep the boat very straight. When paddling with the wind, or even in a dead calm, I find the boat wanders randomly to port or starboard (nautical eh?), and requires a good knee hang and a sweep or two to correct. A bit later - here we go again - same side or t'other. (Kinda like a car with too much toe out)
Am I digging in up front? Should I try adding weight in the rear hatch? Am I that crappy a paddler? (Pls don't say "All of the above").
Here's where I ask for the "Rule of thumb".
How do I try to correct this wandering without resorting to a rudder?
- Re: Rule of Thumb? by LeeG on Jun 2, 2004
- Not a rudder.... by Chris F on Jun 2, 2004
- Re: Rule of Thumb? by Chris Taylor on Jun 2, 2004
Re: Rule of Thumb? by Mac on Jun 2, 2004
- Re: Rule of Thumb? by Kurt Maurer on Jun 2, 2004
- Re: Rule of Thumb? by Mac on Jun 2, 2004
- by on
- Re: Rule of Thumb? by Dave Houser on Jun 2, 2004
- by on
- Re: Rule of Thumb? by LeeG on Jun 3, 2004
Re: Rule of Thumb? by Mac on Jun 3, 2004
- Re: Rule of Thumb? by Mac on Jun 3, 2004
- Re: Rule of Thumb? by LeeG on Jun 4, 2004
- Re: Belly Move Body by Mac on Jun 4, 2004
