Re: System 3 over MAS?
Posted by Terry Mcadams on May 4, 2004
Well, if they say it's compatible, it very well may be just that. However, if you're on the late side of the 8-72 hour cure process, particularly if your work area is warm, you may want to run the sander over the surface to scuff it up a it to ensure good inter-coat adhesion. This would be a good idea even if you're using the same brand of epoxy on each coat.
hope this helps
terry
In Response to: System 3 over MAS? by Baldwon on May 4, 2004
- Re: System 3 over MAS? by Mark Camp on May 4, 2004
Re: System 3 over MAS? by Steve Miller on May 4, 2004
- Re: System 3 over MAS? by Mark Camp on May 5, 2004
- directions?! by LeeG on May 5, 2004
