Re: Slow leak
Posted by Walt on May 3, 2004
Phil I would think that a better way to stop the leak and add some stiffness at the same time would be to lay 3-4 layers of 6 oz. cloth at the base of the rudder shaft. Prior to that if you remove the rudder and pressurise the rudder box the leak may show it self. I wouls think that the box was over-stressed and has a small fracture. If you can locate the crack then you can grind out the bad area and fill it when the cloth or pour is made. Good Luck Walt
In Response to: Slow leak by Ice-Phil on May 2, 2004
