Re: Fittets and plastic t
Posted by RogerJ on May 3, 2004
Mischa, you can make short, small fillets between the ties. Wait for the small fillets to harden then cut the ties. When you do the 6mm fillets go right over the tops of the other ones, then tape. You may have to sand the first set down a bit if you made them too big. Since the first set tacks things in place they do not have to be very big. I don't know how deep my fillets are, I made them a little narrower than my 2" fiberglass tape. RogerJ
In Response to: Fittets and plastic ties by Mischa on May 3, 2004
