Re: bad misalignment
Posted by C. fronzek on May 2, 2004
Jamieson, If the boat always crabs to one side when it's paddled you will soon get tired of it. Unfortunately, there's no way to know how bad bad is until the boat's in the water so you better try to straighten it out while you can. The founder of this company, Chris Kulczicky, of fond memory, advised builders to cut the bad seams open with a hacksaw blade then rewire and retape.I did it myself and sweated blood trying to grind all the old 'glass off. Without seeing the damage it's hard to know what fix will work. I wouldn't let it slide tho'. Charlie
In Response to: bad misalignment by Jamieson Hart on Apr 30, 2004
