Boat Plans |
Supplies |
Sailboats |
Books/DVDs |
Kayaks |
Using West's 407 Low Density Filler
Prior to glassing the hull of my C16, I have needed to fill one small spot along the chine. Using West System 105/206 well mixed before adding the 407 filler (microballoons) I find that the ensuing paste has not hardened after 24 hours (?). Air temp. during the process hovered around 19°C (66°F). Any clues as to why ? Dave
8 replies:
RE: Using West's 407 Low Density Filler
I'm not sure what kind of gap you are filling, but I used West Six-10 Epoxy for the fillets on our MC 16.5. I also used it to glue together some of the scarfs. The stuff applies like caulk and the product literature says the following: "perfect for filling voids and making fillets. It is ideal for stitch and glue boat construction, fiberglass laminate repair and general bondng." I only used it in the main cockpit area and used wood flour thickened MAS in the fore and aft areas beyond the bulkheads. The result was very nice fillets. I taped all the seams before filleting, but if I use this stuff on another boat, I'll skip the tape. Using the wood flour thickened epoxy was messy for me. I may buy another tube to fill all the stich holes and the seams on the outer hull which will be painted. The downside is the $20/tube price.
Dave, to figure out what happened you might mix up another small batch as a test. I had some epoxy that didn't properly harden, and think I spaced out and measured equal amounts of resin and hardener, instead of the specified 2:1 ratio.
Oops, I should have clarified that the 2:1 ratio I use is for MAS epoxies (and many others too). But I see you're using WEST System hardener, which requires a 5:1 mix. Obvious to you, I'm sure, but I don't want to create any unecessary confusion ...
Jeff and OY, Many thanks for your replies. I finally worked it out. West (and probably any other brand) epoxy is hygroscopic. I had foolishly left some unused 105 and 206 in glass jars for about a week. When it came to mixing them, I noticed that the fluid was a milky colour, but went ahead anyway. On my second attempt the same thing happened, but I decided to discard the epoxy before adding 407. I then drew down on fresh material from the sealed containers. This mixed clear, as it should. Added the 407 and by this-morning everything had set perfectly. All part of the learning curve.
That's interesting, Dave. Haven't heard of that before. I've recently been using some 10 y/o epoxy from containers that were stored the whole time with the pumps left fitted. Not a single problem!
Here's an update O.Y. The second batch of West 105/206 that I mixed, but did not use, was left in the mixing cup (I did not discard it ~ only the stuff in the two glass jars). The next day (i.e. yesterday) I thought I'd have a look at it and blow-me-down ! It had gelled. Next question : Why did it not gel with the 407 mixed into it ? No longer a bother, but chemically interesting. You mention having used 10 year-old epoxy stock (well sealed I presume). That's amazing. John Harris mentioned to me that he had, on one occasion, used eight-year old West epoxy which performed perfectly. So much for the "use-by" dates ~ which are probably set for extreme conditions. Next up, glassing the C16's hull. Another hurdle, but fun.
No, unfortunately, my 10 y/o MAS epoxy was not sealed, and furthermore was stored in a cold damp basement. The hardenered turned a dark brown color, so I don't use it for clear-coating under varnish, but it otherwise works fine. I heard a podcast by the owner of System Three who said that epoxy doesn't seem to ever go bad. The MAS people told me to mix up a test batch, and if it cured it was still good to use. So much for the warning dates.
» Submitted by Dave R. - Mon, April 19 » 5:39 AM
Several hours later : I placed the hull out in the sun for a few hours to see if the warming would entice the 407 filler/epoxy mix to harden. No success.
So I stripped the whole lot off and will re-mix and re-apply. (a) Should I clean the surface before re-applying, and (b) What do you recommend I clean it with ?
With thanks
Dave
