Novice
Guys,
First of all, sorry for how stupid my questions may sound. I am a novice in kayak kit building. In addition to that, my question are probably answered on th kit's manual, but I am so anxious that I can't wait to understand a little better.
Subject 1: From the available tuorial available on CLC website, the show as step 18: " hull assembly is complete when the desck has been sanded and fiberglased ..."
- Is there deck fiberglassed too? Theu "outer" part? How to make a nice transition between the fiberglasses where the hull and the deck joints?
- According to the tutorial, the deck fiberglasses should be installed after the cockpit reinforcements. Is that right?
 - Can the fiberglass be sanded after before varnishing?
 Thanks,
 Gui
5 replies:
RE: Novice
Gui, what boat are you building? SEEYA JAck
RE: Novice
1. Yes, on most of the boats here the outside is glassed. Follow this link to see how I did the transition on my WD12 (it should work for any kayak).
2. I like to install the glass first, then the coaming, but either way will work. Try this link to see how to build a coaming off the boat.
3. Once you fill the weave (but not before), you pretty much have to sand the glass to get it smooth enough for a nice varnish job. Follow this link for a nice description of the process
Welcome to the group,
RE: Novice
Laszlo,
Thank you very much for the answer.
Congrats for the documentation that you made available on the web. Awesome. I'll go thru it entirely and I will ask you any doubts that may arise, ok?
Thank you again,
See you,
Gui
RE: Novice
Jack,
I am planning to build a Shearwater for me and Chesapeake 16 for my wife.
Not sure the order though.
Thank you,
Gui
