Bad fillets, then air bubbles
Hi, people. I´m building a S&G Night Heron. Everything was fine until fillets. I´ve used a bad wood floor. My fault. The fillets  were not as smooth as they should be.  Then, in fiberglassing air bubbles appeared.
My question is. Are these air bubbles structurally important?. Must I correct them or they are appareance only?
What do you recomend?
Thanks in advance.
Ivan
RE: Bad fillets, then air bubbles
I´m sorry. I forgot an image. Trying if it works:
https://cid-fdb625df781f8e56.skydrive.live.com/self.aspx/.BlogImages/20100222%20025^_800x600.jpg
Best regards.
Ivan
I´m sorry. Second chance....
http://cid-fdb625df781f8e56.skydrive.live.com/self.aspx/Construcci%c3%b3nKayak
