Boat Plans |
Supplies |
Sailboats |
Books/DVDs |
Kayaks |
Blotchiness after coating & sanding .. ugh
I'm building a Passagemaker Dinghy, early in the process, and have finished my second coat of epoxy, then sanded with 220-grit. But my sanding seems to have been uneven. In my efforts to remove every last shiny bit, it seems like I sanded unevenly. A particularly ugly example appears below. Should I roll on another coat of epoxy and re-sand, more carefully? Or just plan on making it a painted boat ... :-(
RE: Blotchiness after coating & sanding .. ugh
Wipe it down with thinner or mineral spirits. While it's wet it will look just like it will varnished. Paul G
» Submitted by monboat - Sat, February 6 » 11:23 AM
After I had sanded my passagemaker parts they also looked similar however after applying the first coat of varnish all 'blotchy' areas seemed to disappear. Try a small area and see how it looks. I think this is probably a normal occurence.
Alan
