When trimming the deck of my ches 17, I removed the base on my jig saw so I was left with just the saw blade. This way I could work my way around the kayaks changing contours simply by altering the angle of the blade free hand. Its quick and really accurate, leaving only a little wood left for the block plain to take.
Be careful though. This is not the correct use of the tool, so what those fingers...
6 replies:
RE: deck cutting tip.
I should have mentioned that. I have an expensive Porter-Cable jig saw with a fixed shoe, but prefer my cheap Sears model with a floppy shoe that never stays tight no matter what I do to it. -Wes
Hi
I just flipped the kayak over and used the japanese pull saw as lazzlo said, cut easy to about 1mm away from hull.
Trev in OZ
» Submitted by twofootartist - Wed, 1/27/10 » 11:01 AM
You can do this much more safely by simply loosening the angle adjustment on the saw plate.
