Boat Plans |
Supplies |
Sailboats |
Books/DVDs |
Kayaks |
Do you need to epoxy coat the mahogany rub rails or do you just need to varnish them? It was not called out in the manual for the PMD. Thanks, Ron
RE: epoxy on rub rails
Bob, Thanks for the reply. I have already started to coat them. Ron
Ron, you won't be sorry. Unless the epoxy gives you fits like fisheyes or something. But even then, the rub rails are somewhat easily sanded down and you will still have the basic epoxy coating for waterproofing. Good luck! best, bob
» Submitted by Bob H - Mon, September 14 » 12:55 PM
For what it's worth from this novice, epoxy is a sure fire way to waterproof the wood, despite that it adds weight. We epoxied the rub rails on our Skerry just for the extra waterproofing. Then we sanded and varnished over them with the high gloss marine varnish. It's worth the extra effort in my opinion. Best, Bob H.
