End Caps for Pax 20
Are the end caps added after the fiberglass is put on the hull or before?   I note the end caps are larger than the place on bow and stern where they are applied.  Do you  trim them before affixing them or after?  Bill
1 reply:
RE: End Caps for Pax 20
Ideally those "caps" go on before you do the fiberglass sheathing.  It's intended that you do a good deal of shaping on those caps---very sharp at the waterline, gently rounded up at deck level.
