can the epoxy on the hull be sanded before placing th deck glass and epoxy. i had to fill a gap between the deck and hull. if i sand off the what ended up on the hull will this affect the finish?
RE: epoxy problems
Thanks for the vote of confidence. I don't really have a choiceI have to sand. I've just never workrd with epoy before so I'm not sure what can be done. It sounds lo=ike I can work it like any other clear finnish. thanks again
RE: epoxy problems
» Submitted by Laszlo - Thu, 5/21/09 » 6:32 AM
It'll be fine as long as you don't sand into the wood.
