An epoxy "oops"
I was inspecting the inside of the hull and found a spot in the cockpit where I goofed and I have a bubble about 1" in diameter that has air under it. Before I "invent" a solution, are there any suggestions to correct the problem. I has checked the CLC site and others as well to no avail. Thanks, JD
1 reply:
RE: An epoxy "oops"
Two methods that I used depending on the location of the bubble. You might just cut it open with an X-shaped cut, put in a bit of epoxy and press it down. If it's in a very visible spot, cut or sand it off and lay a new patch of glass cloth over it. Feather out the edges after it cures.
