Annapolis Wherry - Request seat top to gunnel measurement for custom rigger.
I am looking for someone with an Annapolis Wherry fitted with the Piantedosi Row Wing that would be willing to measure the distance between the seat top of the Row Wing and a straight edge (plank) set across the gunnels at the pin station (the fore/aft position of the oarlock pins on the rigger).   That measurement will enable me to precisely position the rig that I have built for my Annapolis Wherry so as to duplicate the rest of the geometry of the Piantedosi rig.  I took the dimensions from the cross section view of the Piantedosi  rig at the pin station, (provided by CLC on the web site along with the plan view and profile), but there is some ambiguity as to whether the seat is installed in these diagrams.  There is something very thin on top of the carriage that I suspect that is a seat platform.  If so there is another inch or two of seat that is missing.  The height of the oarlock is referenced to the seat top.  I used the Row Wing diagrams to position the rails, carriage, stretcher, and oarlock in the same relative positions in the drop in unit.  I need this measurement before I lock in the vertical position of the assembly in the boat.  After working on some earlier iterations, it became clear that the least ambiguous point of reference for measurement and calibration purposes was the line between the top of the hull/gunnels at the pin station.
For those interested, following are some pertinent features of this modification:   I did not install the seats.  I connected the two seat thwarts with fore and aft 1”x2” rails to support Latanzo tracks.  The forward end is cantilevered about 1 ft forward of the forward seat thwart.  If I build another (a real possibility if this works out well) I would move that thwart forward to catch the end of the rails.  There is no great force on the rails (just the rower’s weight)  so this is an esthetic issue rather than a structural one.   I installed an additional thwart at the pin station as the forces of the oars will be transmitted to the hull at this point and if necessary via a strut to the aft thwart.  Note that all of the force from traditional rowing is also  transmitted to the hull at this point via the oarlock that is located at approximately this position.   I have used Latanzo tracks, carriage and stretcher bars (www.latanzorowingparts.com), and Concept II oarlocks (concept2.com).  I am having the rigger constructed from aircraft aluminum tubing.  If I can find a source for the knuckles used for the rear struts on the Piantedosi rig, I would not need to weld.
Thanks in advance.
RE: Annapolis Wherry - Request seat top to gunnel measurement for custom rigger.
I love a little DIY. However if it were mine, I would be much more interested in seat-waterline and seat-oarlock than in seat-gunnel.
The hands+legs need to be right. The oar angle to the water needs to be right. For a boat designed for recreational rowing with a row wing, the height to gunnel should not matter too much.
concept2 rowing diagram
The image is from here: http://www.concept2.com/service/oars/setting-inboard . There's more helpful stuff in their Support:Oars section.
m.c.,
You are exactly right.  I want the seat to oarlock height.  The issue is I know where the monorail is with respect to the gunnel and I know where the oarlock is with respect to the gunnel.  I am not sure whether the seat is actually mounted in the CLC diagram I am working from.  I suspect not, in which case I don't know precisely where the seat is.  I realized after posting that the distance from the seat top to monorail would also suffice and does not require installation in the boat.  With regard to the waterline, since the Row Wing geometry has worked well with the wherry, presumably reproducing the same geometry in an alternative rig should work similarly. Positioning the seat at the same height will accomplish this.  I have built a light weight Latanzo style sliding seat assembly typical of sculls, but need this measurement to install it at the correct height. Having done so will reproduce the seat to oarlock height.  This is not a drop in unit.  The rigger is attached at the gunnel.
