Epoxying Seats and Bulkheads before Installing?
Hi everyone, I am working on my Jimmy Skiff from the kit and I had a question: Is it ok to coat all of the interior pieces (and maybe sand them) before I put install them in the boat? It doesn't say to do this in the plans, but for the aft seat, for example, I'm wondering how I will be able to coat the underside with epoxy after it is installed? There wouldn't be enough room to apply epoxy under the seat after it is fixed in place.
This tactic seems to make more sense to me than installing everything, then later struggling to apply epoxy in nooks and crannies and up side down.
Thank you for your help and wisdom!
Austin
1 reply:
RE: Epoxying Seats and Bulkheads before Installing?
» Submitted by Dick Dowdell - Sun, 10/9/16 » 5:49 PM
Austin,
I've not built a Jimmy Skiff, but here is my 2 cents worth. It is imperative that all the the wood in your boat be encapsulated in epoxy resin. This article on the Aging of Stitch and Glue Boats provides many examples of what water penetration can do. That being said, everything in boat building is a tradeoff. Epoxy is heavy and too much epoxy will make your boat heavier. I agree with your idea and these are some points you'll need to keep in mind:
It is a matter of personal taste, but I believe that brightwork, though beautiful, weakens the boat's protective finish because water can penetrate varnish.
Good luck and fun for your build. Building your own boat can be a very satisfying thing.
Cheers,
Dick
