Can you layer epoxy of different brands?
I have the first coat of epoxy down on the deck interior of a Pertrel SG, and want to apply a fill coat inside of 72 hours from initial application.
I'm using CLC-supplied MAS epoxy and am short on hardener -- I'm not sure I have enough remaining for a fill coat. I live on the west coast, where MAS is hard to come by. This is the land of System 3, and I cannot get a resupply of MAS inside of 7-10 days.
Question to you is whether I can use System 3 for the fill coat? Both epoxies are 2:1, and know not to mix and match resins and hardeners between them, but is it viable to layer one over the other?
If not, I'll have to await a resupply and sand between coats.
Thanks in advance...
1 reply:
RE: Can you layer epoxy of different brands?
» Submitted by Silver Salt - Thu, 9/15/16 » 5:17 PM
Have a look at Ocean One Kayaks site here...
http://oneoceankayaks.com/Epoxresl.htm#misc
Lots if epoxy info.
Any epoxy (not polyester) will stick to cured epoxy if it is sanded.
