Working from plans...
Suppose I am cutting both front hull pieces on a boat.
If I cut one peice, can I use the first piece as a template for a router and a pattern bit to cut the second? Does the Okoume plywood chip out? Smooth cut? Best bit type to use?
5 replies:
RE: Okoume and router
Nemo,
Are you running the base of the router against the batten, or some bit against the batten? Or something else? Trying to visualize...
I cut both panels at the same time with a jigsaw. I cut a little bit proud of the line then sand to it. Cutting with a router wastes wood my jigsaw blade is 1mm wide and a router cutter is going to be at least 5 or 6mm wide.
Yeah, the bearing against the batten (which is exactly on the marks), and the base rides on top of the batten. You can attach a little piece of batten to the far edge of the router base to help with balance. Sort of like an outrigger canoe...
Yambo, I separate the part from the sheet by cutting next to the batten first with either a circular saw or jigsaw, primarily just because I don't like to plow full width with my router bit (12mm wide, here).
Not just with Okoume but with any plywood, this is also my intention.
Rough-cut (say 2mm proud) with a jigsaw then use a Master Template to produce 4 panels the same dimension
» Submitted by nemochad - Wed, 9/14/16 » 9:45 PM
Okoume routs wonderfully. But kayak panels are thin, so there's not much edge for your bearing. With a top-bearing, pattern-following but, an inadvertent tilt of the router will the lift the bearing clear of the patter and causes a big divot to be removed. Putting the pattern beneath, and using a laminate trimming type of bit (bearing below cutter) is safer.
I'm a plans builder, and rout all of my panels. I use full-length straight grained battens tacked onto the layout marks, and run my router against the batten, cutting both panels at once, with no fairing/tuning/sanding needed. One cut and done...
