Scarf Joints
Is the scarf joint done on the plywood before cutting to dimension, or after?
In one case that would reslt in a 16' length that is then cut to dimension.
In the other case, it would result in two cut pieces being lined up and joined after cutting.
Is one better? Considerations?
RE: Scarf Joints
You are working from plans? Yes? Not a kit.
Join the full length, then draw your shapes and cut them out.
You have the chance of misaligning your pieces, or having them slip, if you epoxy glue a scarf after you cut the pieces. In addition you don't have to remember that there is a loss of dimension at the scarf overlap.
RE: Scarf Joints
   ...agree, with the caveat that pre-scarfing pieces that are pretty close to your final shape can save a lot of material. Doing this saved a full sheet of ply on each of the CH17's we built, for instance (I also built pattern/templates first, so gluing odd shapes over the templates was just a matter of making sure the pieces fully overlapped/covered the template).
Your choice where you want to go on the risk-reward spectrum.
