I am preparing to epoxy & glass the inside of the deck and hull. My question's are; Do I epoxy and fiberglass completely to the beveled edges? Then redrill the holes and rebevel the edges to remove excess epoxy? Or should I use 1/2 " tape to mask the holes and edges, to keeping them clean.
thanks,
Chucko
RE: Shearwater 17 epoxy & glass
It's that "cured to rock" stage that I was concerned about. I'd hoped to leave the bevels un-retouched. I'll refer to your pictures and instructions many times......Beautiful boat dude....simply Beautiful!!
Thanks,
Chucko
» Submitted by Fishbuster - Mon, 2/2/09 » 5:03 PM
Glass completely to the edges and redrill holes. Your glass will be hanging over the edge actually, use a razor to trim right up to the edge when the epoxy is green, dry but not cured to rock, easiest to do it this way.
http://shearwaterkayak.blogspot.com/
