I'm looking for any insight or tips folks may have for varnishing the many 1/2" openings associated with spaced inwales on the Peeler. I've done a great deal of varnishing in the past, but I'm always looking for the coolective genius of others...brushes, techniques, etc
Thanks, Mike
RE: Spaced Inwale Varnish Input
» Submitted by SurferBill - Thu, 5/12/16 » 7:38 AM
Sand with little blocks of wood wrapped in stick it paper, a paint stir stick wrapped in paper works nice too, just wrap the bottom few inches, a dremel for any thickened epoxy white globs, use the smallest foam brush, it fits nicely in the spaces. Run a drip strip of tape under the inwale. I use rapid clear from Epifanes for the first 3-4 coats, you don't have to sand between coats, then finish with gloss one or two coats. Then do it all again as needed after a few months in the sun and salt!
