Sailboat Rigging Hardware for a Passagemaker
Hey folks,
The tracking number says I should be getting the plans for the Take-Apart Passagemaker on Monday, but I'd like to grab as much rigging as I can tomorrow. If it's not copyright infringement, can someone shoot me a copy of the suggested bits to rig up the gunter sloop version? Knowing me, I'll consider it more of a guideline than a rule...
Thanks,
Chris
RE: Sailboat Rigging Hardware for a Passagemaker
The build manual that comes with the plans has the list of sail rig bits needed, right after the boat construction materials list.
There is also a lot of excellent information at www.pmdbuilders.net
» Submitted by catboater - Fri, 7/10/15 » 10:37 AM
If you go to the Passagemaker page and click on "view contents" tab under "sail package components kit" it will give you a list of the bits included in the kit. Also, if you go to the "line and cordage package" and do the same it will give you the specs on those components. This should give you a place to start.
