Issues with tack welding Shearwater Sport
I just tack welded the deck and the hull of my shearwater and noticed that when I took the deck off today some of the deck seams where off now. Is it possible to heat up the epoxy to slightly adjust for a better fit then let it reset. Not off by much but since its the deck I am hoping for a good fit and finish so I can varnish it. Thank you.
RE: Issues with tack welding Shearwater Sport
So I tried a hair dryer this morning. It has bee about 30 hours and didnt seem to soften it at all. I left it on high for 5-10 minutes and was able to feel the heat on the opposite side. Is it likely set to long already or would I need higher hear like from a heat gun?
You should still be able to loosen seams at 30 hours. Don't be afraid to get it bloody-well hot. You're not going to damage the wood until you get to 450 degrees or something, way beyond what you can manage with a hair dryer.
Off by how much? You are in the middle of "Boat or Furniture" conundrum. I accidently broke off the last 3/4 of an inch of both of my shear panels on my SWS. They were too skinny to try to glue back on. After the kayak is finished, I am the only one that knows what happened. Even with a varnished boat, most likely no one but you will know. Good luck, JRC.
» Submitted by John, CLC - Wed, 11/12/14 » 6:08 PM
Yep. A heat gun (or hair dryer), and Bob's your uncle. You can unstick bad puzzle joints or scarf joints with heat, too, as long as not many days have passed.
